Hi - I've had the 2600 for a few years now - great sound. I have got used to readjusting the volume slider to get both speakers working sweetly. The right one can go silent on me.
Now I have a bigger problem - the volume fades right down and then back up all on its own and the volume slider does not behave as I would expect.
Can anyone advise please? Thanks- Richjaffa
ps - I don't believe in poltergeists...
If both channels are affected at the same time, it could point to a common circuit, perhaps a voltage supply and/or regulator problem.You could choose to clean the volume potentiometer while in there.
Hi Dillen - just cleaning the potentiometer did the trick. I'd not had it apart before - very dusty and an ancient spiders web inside - little critters. A blast of gas duster and a careful clean and its sweet as a nut. Thanks. r
good one
