I consider to buy a second hand A9 if I can find a MK2, as I would use the multiroom feature. It seems sellers usually do not know whether they have the MK1 or MK2 version. I also found it difficult to find information about the differences when I searched Google and this forum.
Is there an easy way I can distinguish between the two by asking sellers for known functionality, ports or labels on the hardware? For example if only MK2 features Spotify or have a new input port?
Mk2 has a little Bluetooth logo on the top edge. Simple
Lee
Great, thanks! Seems there are actually no Mk2s out there after all..
The MKII hasn't been out that long so not that surprised many aren't available yet.
Dave.
Hi!
Does anyone know if type 2890 is MK1 or MK2?
Best regards
Ola
