LC2 and Beo4 problem.
This post has 7 Replies | 0 Followers
BeoGreg
South of France
Posts 1,417
BeoGreg Posted: Sat, Mar 17 2018 11:13 AM
Dear all,
Since not long ago I loose control of my LC2 with the Beo4 after a power out.
The LC2 works by hand but not with the remote.
After power on again for a few hours the remote works again but today it doesn’t (while it works by hand).
Any clue ?
I suppose that if the fuse was dead the light won’t work at all.
Millemissen
Flensborg, Denmark
Posts 14,680
I have a similar problem with one of my LC1’s.
Works manually, but not with the remote.
Faulty ir-receiver, I guess.
Probably easier to repair on a LC2 than on a LC1 - assuming you can get the parts needed.....from another LC2.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sat, Mar 17 2018 11:47 AM
Ir can be fixed on LC2, no problem. Touch etc.
Indeed a LC2 is easier to acces than LC1.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sat, Mar 17 2018 12:27 PM
Ok guys thank you.
I think I bought it around 1997 it’s more than twenty years old.
Will ask my dealer/technician what he can do for an IR sensor.
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Sat, Mar 17 2018 12:45 PM
@ BeoGreg
There are plenty of repair guides around. These Light Controllers can like any old school B&O gear almost always be repaired.
Where did all these greatl accessories go by the way?
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sat, Mar 17 2018 5:37 PM
Just had my tech on the phone who said over a dead fuse never had an IR sensor case.
I asked if he had a lutron he said yes, but I realise checking lutron site that it’s not a direct LC2 replacement.
Will go to the shop on tuesday to see that lutron stuff.
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Sat, Mar 17 2018 8:33 PM
It's usually down to dying electrolytic caps,- once replaced the receiver will be back in business.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sat, Mar 17 2018 9:54 PM
Believe it or not, after 3 or 4 hours LC2 works again with remote.
Until the next power out...
Page 1 of 1 (8 items) | RSS
