Hi there!
I was just taking a closer look at BL50 specifications and saw a Digital Power Link there. As I couldn't find anything on Google, I'd like to ask the community:
Does anyone knows what it is? Just a simple SPDIF via Power Link cable or anything special from B&O?
Cheers,
Dante.
BTW, what about Wireless Power Link? Is it the same thing as Wisa?
DPL is for time being used to connect the slave speaker to the master speaker (BL50/90).
Official definition is: 'Includes proprietary B&O data channels for inter-loudspeaker communication'.
It is based on the AVB (AudioVideoBridge/Bridging) technology.
Since there is a DPL-input port on the master speaker and the BS Core has a DPL-output port* it (IMO) is likely that it will be used for the communication
between source systems and the speaker/s in the future - as a successor for the old analog PL.
Note! There are no official statements or informations on this yet!
The WPL is basicly the same - using WiSA as the protocol for the wireless connection
*This output is declared 'for future use' in the specs of the BS Core.
Hope this helps answering your question.
So, if the audio encoding is still following the traditional SPDIF format then the audio processing quality will be the same when compared to a BL5?
I did not say that - SPDIF is a specification, that can not be tweaked.
It is a digital protocol - Audio with Sampling Rate 192 kHz and with Bit Depth 24 (fixed) plus the PL-data.
That should be sufficient, I am sure.
As I wrote, we will have to wait for further details.
According to bola 50's service documents it's 100Mbps Ethernet
