https://www.whathifi.com/bo/beolab-50/review
I'd like to kindly ask Beoworld members who already own a pair of BL50 to comment the Whathifi review...
Do you agree with the evaluation?
I don't have a pair of BL-50, but it seems that they rated the BL-5 similarly.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Hi. What is the problem "internet has an effect on the workings of the dsp" causing you. Are we talking bad sound or noise or something else. And for your information the DSP is almost identical. The only difference is that the Master speaker has an extra connector on the DSP due to that the Master has all the inputs. There is a new SW out (approx 10 days old)...are you up to date on that one. Best regard EJ
Mikipedia:Yes i know the dsp is roughly the same. But i meant the physical tollerances in the actual chip. Not in how it works persee, but apparently the tollerances in the silicon have an effect.
The only area where physical tolerances can have an effect would be in the interface between the DSP and the Memory.
Some of those interfaces are running at the very edge, and technically you could argue it's down to the actual silicon.
Could you be a bit more specific in describing the noise and issues?
Mikipedia:I don’t agree with it on several levels no. First and formost they have “competitors” to the bl50’s that are nearly 3x the price if you scroll down. Secondly build quality, chassis and such are top notch. The electronic bit’s are getting close to rubbish imo. Iam on my second pair now and once again the dsp (b&o claims) is causing issues. Somehow the internet has an effect on the workings of the dsp and they even told me their dsp’s are not the same from speaker to speaker. They’re so far out of the original design spec that the normal software can’t handle it, so apparently they’re working on rewriting the software. Iam now 6 months in and still no solution. Iam currently writing a letter of complaint and i am on the verge of returning them. I’ll go into it more on tomorrows BeoTalk podcast i do with erikvonagnar from the forum aswell(it’s on youtube, link down below), but this is fairly comprehensive. Thirdly regarding the review, the terms they use i feel are somewhat vague. When these speakers work, they are great not just good. The stereo separation is bizar in a good way. When i only have the bl50’s playing while watching tv, i can’t tell the tv isn’t playing untill iam around 4-6 inches away from the tv. I played some of the tracks they used and i van’t figure out why they deduct them points. With these speakers you’ll hear so many more sounds that you had no idea were there. I gues in the end i would come to a 4 out of 5 stars too, but for very different reasons. If the build quality was there it would’ve been an easy 5 out of 5 stars New: Beolab 50's, Beolab 18's, Beovision eclipse. Mikipedi4 on YouTube https://www.youtube.com/channel/UC0WLHXZuA1GANMzYcAn5_xg Old: Beolab 1's, beolab 2, beovision 10-46, overture 2300, beolab 8000's, beolab 4000's, beovision avant 32" etc. etc.
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
The LG panel is not getting updates? To paraphrase many here, who cares if the video isn't perfect, the soundbar glued onto it sounds awesome!
Software seems to be something that B&O is genetically incapable of doing well, sadly.
Jeff
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
My eclipse also makes a weird whistling noise when i shut it down, but apparently that’s normal according to b&o HQ.
Reminds me of an old joke. Guy takes his car to the dealer. It runs rough all the time. Oh, says the guy they all do that. It doesn't start easily when its cold. Oh, they all do that the mechanic says. It gets awful gas mileage. Oh they all do that.
Finally the guy says, don't tell me that! My wife has the identical car, same year and model and it doesn't do that!
Mechanic says, oh, well then, tell her to bring it in and we'll fix it.
Sorry, not making light of your experience, that has to be frustrating as can be and not what one should expect for a product in that price range. That is, about double what a fairly decent car costs.
Mikipedia:Look iam not making this up, this is what b&o HQ tells me. But i must say they have elevated not really answering anything to an art form. Just watched a movie on tv and it was ticking galore again. I have them wired with cat7 cables. Weirdly with wisa the ticking is mostly gone. But then i have issues with them turning on, they usually don’t sync up or they don’t come on at all. If they turn on, it takes them several tries. Tweeters come up and down up and down up and down, mismatched between the speakers. Sometimes only left, sometimes only the right one. And then once they’re on they echo and you have to go to a different speaker group and back again and then they work. This is besides the point when you connect the bl50’s via wisa they don’t sound the same and they actually sound worse but louder. So far everything has been replaced and iam still no further. Cat7 cables, power cables, power extension block with surge protector(even tried one without surge protection), tried them on a separate power socket too, my beoremote one(power button stopped working), the bl50’s speakers have all been replaced. The only thing that hasn’t been replaced is my eclipse. My eclipse also makes a weird whistling noise when i shut it down, but apparently that’s normal according to b&o HQ. So yea, you tell me how optimistic i can still be?! this has been going on since late sept/early october last year. New: Beolab 50's, Beolab 18's, Beovision eclipse. Mikipedi4 on YouTube https://www.youtube.com/channel/UC0WLHXZuA1GANMzYcAn5_xg Old: Beolab 1's, beolab 2, beovision 10-46, overture 2300, beolab 8000's, beolab 4000's, beovision avant 32" etc. etc.
Hi, my name is Chris and I’m located in Germany.
i just picked up a pair of Beolab 50 and a BeoSound Core.
For some reason I’m not able to connect them right. (Master cant find Slave / connected via Powerlinkcable)
Could a Beolab 50 Owner please tell me the correct way to connect everything ?
I have no chance to get a hold of my B&o Dealer the next 3 Days. (That’s way to long:)) )
Ekopf:Hi, my name is Chris and I’m located in Germany. i just picked up a pair of Beolab 50 and a BeoSound Core. For some reason I’m not able to connect them right. (Master cant find Slave / connected via Powerlinkcable) Could a Beolab 50 Owner please tell me the correct way to connect everything ? I have no chance to get a hold of my B&o Dealer the next 3 Days. (That’s way to long:)) )
Thank you for your help.
The cable that connected the Master / Slave is not working.
i just tested a regular cat5 cable and now everything works fine.
Mikipedia:Tweeters come up and down up and down up and down, mismatched between the speakers. Sometimes only left, sometimes only the right one.
Mikipedia:Hi esax, yes iam sure. Unless all the cables we tried were all faulty at my place but they work just fine at my dealers. So no it’s not the cables no. New: Beolab 50's, Beolab 18's, Beovision eclipse. Mikipedi4 on YouTube https://www.youtube.com/channel/UC0WLHXZuA1GANMzYcAn5_xg Old: Beolab 1's, beolab 2, beovision 10-46, overture 2300, beolab 8000's, beolab 4000's, beovision avant 32" etc. etc.
