After Moment update, strange behavior BL3500 via NL/ML converter
athos
Posts 46
athos Posted: Wed, Mar 28 2018 6:35 PM
Hi there,
I have;
Beosound Moment
Beoplay V1 with speakers connected to it
NL/ML converter.
BL3500 in kitchen
All three connected via network
Since I updated the Moment last week, I have the following issue. When I choose "Radio". in my kitchen, the moment in my living room starts up and the radio is played in my kitchen. When I go to the living room and put on the V1 television, suddenly the radio sound on my BL3500 changes in the sound of the TV, while the display of the BL3500 still shows radio. before update, never a problem. Any idea?
StUrrock
Posts 995
StUrrock replied on Wed, Mar 28 2018 9:27 PM
athos:
Hi there,
I have;
Beosound Moment
NL/ML converter.
BL3500 in kitchen
sell the bl3500 and converter and get the newer model speaker wired by cat cable
otherwise it’s always a bodge up job
athos
Posts 46
athos replied on Wed, Mar 28 2018 9:52 PM
Thnx for reply. Before upgrade sw of Moment, problem did not occurred. Oh, and I have BL20's, BL17s and a BL2 connected to my V1 TV.
No budget for BL35 at the moment (and to be honest, don't like the looks of them too. But thats a matter of taste, I know...
beojeff
USA
Posts 2,012
beojeff replied on Wed, Mar 28 2018 10:38 PM
In a properly programmed setup, your BL3500 can work well and continue to give you years of use. I have 2 BL3500 units and once considered replacing them with the new BeoSound 35, but I just don't see the compelling need just yet.
I, too, had some trouble with one of my BeoSound Moments after the recent upgrades. I found that it somehow lost it's pairing with its NL/ML Converter. You might check to see that the Converter is still programmed properly -- including the source mapping. Check that the BeoSound Moment is setup to use the NL/ML Converter through its settings. Also, a good power cycle of the devices can clear up some issues.
beojeff
USA
Posts 2,012
beojeff replied on Wed, Mar 28 2018 10:43 PM
I just re-read your original post and saw you're using a V1. I don't know whether a converter has the function of allowing the Moment to use the V1. If that's not the case, you might check to see that the Moment's settings are correctly set to use the speakers of the V1 -- if that is what you're doing. I found that some settings got lost in the upgrade.
athos
Posts 46
athos replied on Thu, Mar 29 2018 8:37 AM
Thnx for reply. I will check your recommandations. Not shure about the NL/ML converter if anything has changed there.
Page 1 of 1 (6 items) | RSS
