My BeoMedia 1 stopped working for the third time (doesn't start). I won't bring it in repair this time, but was wondering if spares can be found somewhere? Thanks.
Guy
Hi Guy,
everything except the ml-card is standard PC stuff. If you can repair beomedia 1 yourself depends on your technical knowledge.
Most of the times the internal power adapter is defective. The capacitors are cheap 85°C ones which will blow.
Another problem is the harddisk drive. B&O uses standard 8/7/365 days desktop harddisk drives with limited lifetime compared to 24/7/365 days enterprise drives.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
