Hi there!
I have an old Beogram 3000 (5228) in good condition but for some reason it is always turned on.
It doesn't matter which position the power switch is in - the motor is always running.
I tried cleaning and checking the contacts but it seems to be alright.
Maybe it has something to do with the old voltage converter? Can anyone point me in the right direction so i can fix it?
Thank you.
Kind Regards,
Christian Leicht
https://leicht.io - B&O Custom Parts & 3D Models
