BeoGram 8000 Photo-resistor.
This post has 1 Reply | 0 Followers
kimberley
Posts 19
kimberley Posted: Mon, Apr 16 2018 11:42 PM
I've been told that the photoresistor used with the bulb and shutter for controlling the tracking of the arm on the BG8000 (and the BG8002?) is no longer available.
Is there a source for these?
If not, is there a 'work-round' for controlling the arm tracking another way?
I've tried searching old postings here but haven't found an answer.
It would be a great shame if these impressive turntables are one by one to become elegant paperweights when they can no longer play records.
Saint Beogrowler
Saint Paul
Posts 780
kimberley:
Not quite an answer, but this might help.
http://beolover.blogspot.com/2016/02/beogram-8002-strange-behavior-after-play-arm-moves-2cm.html?m=1
I tried the photo resistor he mentioned (gl5549) but it was difficult to adjust correctly. It turned out my lamp was worn but not dead so I replaced it with an LED as mentioned in the beolover post and was able to use the original photo-resistors.
So, these are fixable.
Page 1 of 1 (2 items) | RSS
