How is this upgradable , is it correct i can not find an eprom ??
if it is eprom upgradable does anyone have the .bin or .hex file ??
B&O , ......and some more
A friend of mine had it done in his Cd 6500 about 20 years ago, I believe he just had the eprom replaced.... Maybe he still has the part number... but I don’t think it is available anymore.
Søren
part will be more than the value of the device ( if available ) .
i think the only way will be programming the eprom myself .....
so the data file would be the best help
