Anyone know of a good source for Beocord 9000 belts in the states? If not, I see Thakker has them, would that be the best source?
You will want the two belts and four rubber wheels for a Beocord mechanical restoration. Get the belts and wheels from Martin (Dillen on the forum). His belts and rubber wheels are proper replacements for the originals. Here is an old post I made when I restored my Beocord 9000.
Thanks Sonavor!
So I read your old post, funny to see that the broken left spring is common. I had just received the Beocord 9000 today and removed the transport, there was the spring laying on the circuit board. Took a while to figure out where it went, I used JB weld to glue it back in place. I didn't know there was supposed to be a bearing in the slot.
