I have a pair of Beolab 6000 speakers. I have bought new woofers but need to replace the double sided tape that holds them in place. Does anyone know exactly which type I need & where to buy it from? Thanks.
They should be held in with self tapping screws!
Regards Graham
There are no gaskets unless you mean the lengths of black drought excluder between the woofers.
