Motor overload protection circuit kicks in.Belt too tight?
thanks for the answer. the belt was changed to the original. how to check?
ssv70: thanks for the answer. the belt was changed to the original. how to check?
Does this mean, that you changed the belt back to the original - and it still fails?
Check that the tape reels can be rotated easily by hand, when the brakes are released.Many of these decks have started to seize up in dry lubricants. - From age and lack of use.
Thanks for the answer! I will give for prophylaxis. Where can I get a quality service manual
Downloadable from here:
https://www.beoworld.org/manuals_view.asp?pid=952for silver and gold members (Well worth the small cost).
See also here:https://www.beoworld.org/article_view.asp?id=87
After disassembly and lubrication, the problem has repeated! When you disconnect the masterlink, everything works fine. When the masterlink is connected, after 5-10 minutes it goes into standby mode. The masterlink is connected to BV 11 via NL / ML. What should I do?
Is there any "auto stand by " setting menu for ML connections on BV11 ?
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
I do not know where the standby mode on BV 11 for ML is turned on. When the CD on Ouverture is running everything is fine
