Beomaster 5000 Repair and Service
This post has 16 Replies | 1 Follower
SurreyNick
Posts 29
SurreyNick Posted: Thu, May 17 2018 9:19 PM
Hello, I am new to the forum and hope I can get some advice regarding a Beomaster 5000 Type 2322 which I acquired today.
The unit powers up OK and it recognises the deck (Beogram 5005) and there is audio output too.  The problem I have is that the front panel doesn't open when the open button is pressed and none of the controls work when pressed either.  There is no remote control with the unit so I need the built-in control panel to work.
Does this sound like something that could be a relatively easy fix, or is it going to have to go to an expert service engineer?
If I tackle it myself has anyone encountered and fixed a similar problem?
I have downloaded all the service manuals and user manuals just in case.
Nick
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, May 18 2018 7:15 AM
Broken ribbon cable from the front panel to the connection board.
Common fault.
Bridge it with thin flexible wires.
(A bit fiddly)
SurreyNick
Posts 29
SurreyNick replied on Fri, May 18 2018 12:55 PM
Thank you Martin
I will begin as you suggest and will let you know if it solves the problem.
Nick
SurreyNick
Posts 29
Thank you Martin
Nick
SurreyNick
Posts 29
OK.  I have exposed the ribbon cable (see attached pic) and it looks to be the offending part, thank you Martin :)
Before I attempt the repair, I'd like to just check I'm going to do it correctly.  On the attached picture I have numbered the connection points and drawn a double ended arrow.
  1. The ribbon cable seems to have 7 connections only of the 10 possible.  These are (as I have numbered them) 1, 2, 5, 6, 7, 8, 10.  Is this correct?
  2. Should I solder the wires between the two points indicated by my red arrow?
  3. Would Litz wire be the best thing to use, and if so, how many strands would you recommend (10, 48, 63, 84 etc. etc.)?
I would like to make a once-only repair so your advice would be most helpful.
Thank you
Nick
Dillen
Posts 13,191
Dillen replied on Sat, May 19 2018 6:33 PM
I think all 10 pins are used.
The others may have been soldered on the other side of the board.
Yes, bridge them one by one using thin insulated leads.
There's not a lot of room for thick cables, but desoldering and removing the broken ribbon cable frees up some room.
AdamS
Posts 373
AdamS replied on Sat, May 19 2018 9:06 PM
If it helps, I’ve repaired two of these using computer ribbon cable - it’s small and flexible and fits into the space available nicely.
SurreyNick
Posts 29
[Using computer ribbon cable]
Did that involve dismantling the front control panel to get to the back of the pcb?
It will be much neater if the broken ribbon is replaced with a new piece of ribbon, so I like this idea, but I am concerned disassembling the control panel is going to be tricky and/or might damage the buttons etc.
Is disassembling the control panel straightforward, and if so, how is it done and what precautions need to be taken?
Thanks.
Nick.
AdamS
Posts 373
AdamS replied on Sun, May 20 2018 12:00 AM
Yes, it involved dismantling the control panel. It’s a bit fiddly but not difficult!
MediaBobNY
Greenwich Village, NYC
Posts 1,106
You'll note that none of the other 3 stacked Beosystems had a drop-down drawer similar to the 5000.
-The controls on the receiver were insufficient to control necessary functions such as. bass, treble, & balance.
-Remote control operation is so much more convenient.  You'd be better off just getting a Master Control Panel 5000 (6 currently listed on US eBay) and, optionally, a Terminal 5000 for day-to-day hand-held remote operation.
SurreyNick
Posts 29
SurreyNick replied on Sun, May 20 2018 12:46 PM
Right.  I will see if I can dismantle the control panel in order to carry out a nice neat finish.  I know it won't make a jot of difference for operational purposes, but it will make me feel better about it.  Daft, or what eh! :)
Once I'm sure the amp works perfectly I'll also see about getting one of those remotes too.
Thanks.
Nick
Saint Beogrowler
Saint Paul
Posts 780
I like the flip down panel for when I'm near the system and want to switch to a non-datalink source or control the volume.
I used computer cable the first time and it was hard to make it look perfect(although my solder skills have improved since then.) I later used something like this:
https://www.mouser.com/ProductDetail/Molex/25001-1004?qs=sGAEpiMZZMuuPJj6pSfD6WShYspnZoZHoTxWRsUyamg%3d
The ends are pre-soldered into nice leads and there is no stripping and pre-tinning needed.
SurreyNick
Posts 29
All repaired and working beautifully Big Smile
Thank you all for all your input and assistance. I couldn't have done it without your help.
Next I have to repair the Beogram CD-50.
Nick
Oh, and I have now bought a Master Control Panel too.
Saint Beogrowler
Saint Paul
Posts 780
Nice work. The CD50 Is great when it is playing
Dillen
Posts 13,191
Dillen replied on Wed, May 23 2018 6:29 AM
Saint Beogrowler:
But not quite as easy a repair...
solderon29
U.K.West Midlands
Posts 764
solderon29 replied on Wed, May 23 2018 10:12 AM
I have five or six BGCD-50's,and probably need therapy too?I just like them and the sound quality they produce.
They can be "challenging" to repair as Martin suggests,and I have the teeth marks along the edge of my work bench as testimony to that.Very satisfying to get them working well again though!(the CD50,not the teeth!)
Nick
SurreyNick
Posts 29
SurreyNick replied on Wed, May 23 2018 12:54 PM
Well, I'll open it up at the weekend and see if I can work out what's what.  I thought I was just going to have to sort out the disc drawer, which has slipped out of its guides, plus the drawer door which hangs slightly open.  But I have a more serious problem.  I had it plugged in and on standby when all of a sudden there was a bang and smoke.  I'm hoping it's just a cap that has exploded and that it hasn't destroyed a complete PCB.  I expect I will be starting a new thread if it looks bad.
Nick
Page 1 of 1 (17 items) | RSS
