Hello!
I need some help.
I have a Beovision 9 , and i need to contact my laptop to tv.(HP Omen)
Unfortunately i have only Beosystem 2.
Can i use directly Hdmi cable pc to BV9 without Bs2?
Need a special hdmi cable or a flat hdmi cable for full hd resolution?
Sound from laptop will work or not?
Thank you for helping.
All the best!
how does a beovision 9 end up with a beosystem 2?
the Bsys3 sits behind in a cradle..
Bvision was 4-50, which I changed.
Unfortunatly missing this part from behind.
I would like to use a laptop with BV9
