Hello all,
Is it possible to use a single BL4000 connected to the "center" powerlink socket on the Beosystem 3? Would it play in mono? If so, does the L/R switch position matter?
Thanks!
-Tucker
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000, Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
Hello Tucker,
Yes, you can use a single Beolab 4000 in the Center Powerlink socket of the Beosystem 3, either speaker setting can be used in this case and this will work perfectly.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
