Hey there! Does anyone happen to know the correct screw size to attach the BS9000 to a horizontal wall mount?
On top of that... does anyone have a horizontal wall mount or table stand they would part with?
Thanks in advance for any info!
-Tucker
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000, Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
It really depends on the wall. Stone/brick wood plasterboard will all need different fixings.
dear eddie,
I suppose he means the screws on the back of the beosound 9000 you need to put in order to be able to but the bs9000 on the wall mount.
Same principle if you need to but it on the high floor stand.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Not sure if this helps, but this is from the installation manual - it doesn't mention anything specific regarding the screws, though:
Correct! I am looking for the screws to mate the BS9000 to the bracket. Not worried about the fasteners to mount to the wall.
Roger: Not sure if this helps, but this is from the installation manual - it doesn't mention anything specific regarding the screws, though:
So it looks like I may need some screws with spacers...
Hi Tucker,
you can order part nr. 3390533 which is 'Bag with parts' containing the for screws (4x20 mm ???), the four bushings ( ??? ) and the four rubber feet.
It still should be available.
Ralph-Marcus
Thank you!!!
M4 x12mm countersink bolts are perfect for the table stand.
Maybe 10mm length could work for the flat mounts.
