Upgrade Beolab 3500/Beo4
This post has 3 Replies | 0 Followers
Abakus2007
Posts 68
Abakus2007 Posted: Fri, Sep 28 2012 12:26 PM
Good day all and thank You for a splendid forum - have found answers to all my questions until now...
After my Beosund Overture broke down I've invested in a Beomaster 5/Beosound 5 which works great with my Beolab 8000. The Beolab 3500 in the kitchen shows A.TP2 instead of N-MUSIC so I guess a software upgrade would be in place. The real problem is that I can only start Beolab 3500 on the display - when started from the Beo4 it first shows RADIO (same as when started from the display) but then, instead of finding the source N-Music, it stays silent. The Beo4 is EE 3.4 SW 3.0 - would maybe an upgrade on that solve the problem.
Thanks in advance
Mikael Baaz
Vienna
make an educated guess
Posts 1,090
Vienna replied on Fri, Sep 28 2012 5:56 PM
Hello & welcome to the forum!
If you don't use your Ouverture anymore (and the BSd/BM 5 is the only audio source)
the IR command "RADIO" can be "re-used" instead of "N.RADIO" ,
the command "CD" instead of "N.MUSIC" .
Chage in the menu "SETTINGS" the "ROLE" from default setting N.MUSIC = "N.MUSIC" > to > N.MUSIC = "CD"
and from default setting N.RADIO = "N.RADIO"    > to >   N.RADIO = "RADIO".
If "RADIO" and "CD" are still needed for a "conventional" B&O audio system only an update of your BLb 3500, the Beo 4
and very likely the audiosystem will solve the issue. (software and possibly some hardware updates required)
Abakus2007
Posts 68
Abakus2007 replied on Fri, Sep 28 2012 10:06 PM
Amazing!!  tks Vienna !!
they are the only parts in the system so far. Changing the settings I can again control the system with the "old labels" CD and RADIO which my old parts recognize.
Again a thousand thanks!!!!
/Mikael
elephant
AU
Posts 8,219
elephant replied on Sat, Sep 29 2012 6:06 AM
Abakus2007:
Vienna is one of the most informed people I know, his knowledge of tweaks is encyclopaedic !
BeoNut since '75
Page 1 of 1 (4 items) | RSS
