Hi! My turning on volume of BS9000 is very high ( no matter the turning off one). Can it be adjusted?
thanks
Liviu
Yes.
Ralf
PS: Why not read the referencebook that is available online on the offical b&o website?
I never owned one of these and only serviced a few but I seem to remember that to store the soundsettings as defaults, you need to set everything as you like it and press OK twice.I'm sure that others will chime in if I'm mistaken.
And I agree on the reference book. It must be in there.
Ralf,
i don't want to start a flame. I just received BS9000 yesterday evening and saw this problem in the morning before leaving home. I know I can read the guide book or google the problem, but being a member of a nice comunity I thought that I might get a quick answer. If you bothered to answer me instead of being sarcastic: "yes/ why don't you read the book?" I think it would have been easier ( and elegant) just to explain.
if my question bothered you pls excuse me and next time just ignore it.
Thanks!
As you know - I answer lots of question on this forum - helped you out before as well....... It just seems - pls don't feel offended - people tend to ask on a forum instead of searching, this way making other "work".There must be reason for a) manuals/reference books and b) search facilities.
(I was not being sarcastic, btw, tried to be polite - I did not write RTFM either. ...)
PS: Oh, enjoy the BS9000, love the design, but my wife won't let me exchange the BS3000 with it.
WFA ( wife approval factor:) of BS 9000 is quite high. I will check it today because my wife wasn't home yesterday. That's the reason I wanted to find the fix for the volume problem as soon as posible ( before I arrive home).
I didn't forget your help, as I much apreciated it, that's why I didn't understand your minimalist answer: ÿes" :)))
Regarding B&O guides...I find them a bit unfriendly and incomplete (searched a lot for Beo 4 tips and tricks.....)
Best regards
I assume you've fixed the issue?
If not, just turn it to volume you desire and press OK (on the machine).
Next time it starts it will start at your selected volume rather than last volume.
Cheers
Beology,
beer or wine? :)) I owe you !
Thanks a lot!
I'm on iphone and not so easy to check guides, so your answer healed my wound:)
No worries,
You're welcome!
