Converting Beosystem 6500 to Masterlink
This post has 25 Replies | 2 Followers
DMacri
United States
Posts 881
DMacri Posted: Sun, Apr 23 2017 9:11 PM
If I understand this correctly, I can convert my BS6500 to a ML system using a Beolink converter (1612) and using Beolink passive units (1658) for each of my link rooms. If so, would I also be able to connect my BS4000 so I can share music from my BS6500 in my parlor with the BS4000 in my bedroom and the other way around? If not, what are my limitations? Thanks.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Apr 24 2017 8:17 AM
this works if the Beosystem 4000 is on a software level which allows it to be set to A-Opt = 6.  I guess  this was possible with Software level >= 2.1
Every source in a room with an source can be selected directly and the other rooms sources with the prefix 'LINK' and the source. In a room with only speakers you get the main room sources with the source buttons. The link room sources should be possible if the main room is _not_ active. If the main room is active the Beomaster 6500 _can't_ route the local source to the local Amplifier  _and_ simultaneously the link source to a 'passive' link room. Such a function is only possible with a BeoCenter 2 (DVD or Audio) or a Beosystem 4.
I hope this helps a bit Smile
Ralph-Marcus
DMacri
United States
Posts 881
DMacri replied on Sat, Apr 29 2017 11:47 PM
This was just what I was hoping for. Thank you very much!
Dom
DMacri
United States
Posts 881
DMacri replied on Sat, Jul 1 2017 12:12 PM
Hi all, could anyone explain (or point me to a link) that describes the different versions of the 1658 Beolink passive? I'm planning to add these to my BS6500 system and I see there are different styles - some appear to have a power button and LED, and others don't. Plus there are all the different software versions. I'd like to be able to target my eBay search to just the models I can use.
Dom
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Jul 1 2017 2:06 PM
Beolink Passive and the similar ML/MCL converter are explained on this page: https://www.beoworld.org/beotech/ml3.htm
As you can see from the part numbers, as long as you get the 1658 or 1653 you will have the 110V versions.
You can probably use a mix of them depending on availability.  I think the latest SW version is 1.3, but perhaps someone out there knows better!
(EDITED: To correct an error!)
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Jul 1 2017 2:09 PM
Actually, see Berlin's 18 Feb post here: http://archivedforum2.beoworld.org/forums/p/9438/82763.aspx#82763
You probably want SW version 1.5, or 1.6.
DMacri
United States
Posts 881
DMacri replied on Sat, Jul 1 2017 7:49 PM
Thanks, Guy. So I will look for 1.5 and higher because I want A.Aux capability.
Dom
DMacri
United States
Posts 881
DMacri replied on Sat, Jul 1 2017 8:41 PM
Ok, so many of the second hand units I'm finding for sale do not have a sw version on the label, but do say made in the Czech Republic. I've seen some units marked made in Denmark with ver. 1.4. Could I assume the Czech units have 1.5?
Dom
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Jul 2 2017 10:44 AM
Firstly congratulations on winning a prize last night!
With regard to the passives, I have had a look through the European sales and like you can only find the SW version stated on the label of the Made in Denmark passives - mostly 1.3 but a few 1.4s.
It does seem logical that the Czech ones would be at the very latest SW versions - 1.5 or even 1.6, and that logic has been expressed before here: http://archivedforum2.beoworld.org/forums/p/13291/115385.aspx#115385
DMacri
United States
Posts 881
DMacri replied on Sun, Jul 2 2017 11:53 AM
Thanks, Guy. I was very pleasantly surprised by the prize drawing. And thanks for the help with the beolink setup. I'm really looking forward to setting up the BS6500, but it's a little bittersweet because I will be putting my BS5000 away for good.
Dom
DMacri
United States
Posts 881
DMacri replied on Thu, Oct 4 2018 10:15 PM
Ok, so my BS5000 finally started shutting down, (need to install Martin’s repair kit) so I put the BS6500 in place instead. Changed the MCL82 boxes for MLC2 boxes and everything seems fine. Relay problem on the Beomaster that I will have to sort out, but I may just switch to powerlink in the main room first.
I added a Beolink converter and a Beoport 2. I installed BM-link on my Mac and updated the Beoport firmware. Other than that, it doesn’t seem to do anything. I’m guessing I have some setup work to do.
Do I need the IR receiver on the Beoport in this configuration? I only have a Masterlink cable between the Beoport and the converter. I thought a Beo4 set to N music would work right from the Beomaster or link rooms. Not quite, correct?
Dom
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Oct 4 2018 10:21 PM
Me again!
I am pretty sure that to work with Beoport/Beolink PC2, the rest of your system has to be N.MUSIC/N.RADIO compatible.  This started with BS3000, according to the info here: https://www.beoworld.org/faq_view.asp?id=20
Hence unfortunately it will not work with/from your 6500.  Adding an IR receiver to the Beoport would however allow it to work as a stand alone system - effectively giving Beo4 control of your Mac.
DMacri
United States
Posts 881
DMacri replied on Thu, Oct 4 2018 10:34 PM
Would it work if I added a BeoSystem 3 and my Beosound 4000, or does everything have to be completely compatible?
Dom
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Oct 4 2018 10:39 PM
Sorry - I am not sure!  If you try that, perhaps you would have to make the Beoport the 'audio master', as it mentions in that FAQ that I linked to.
I remember several years ago trying a BC9500, BV3-32 and Beoport setup and getting very frustrated - I think that the lack of N.MUSIC compatibility in the BC9500 stopped the rest of the system from talking to each other.  I gave up in the end.
DMacri
United States
Posts 881
DMacri replied on Thu, Oct 4 2018 10:46 PM
Ok Guy, thanks. I’ll try it and report back if it works. The BeoPort was cheap, so no great loss. I thought it would be nice to have that level of control. I think I want the BeoSystem 6500 to be the audio master and the BeoSystem 3 to be the video master in this setup.
Dom
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Oct 4 2018 10:53 PM
No problem! When I bought my BeoPort it was also cheap and to be honest it was quite good fun to play around with.  I did use it for a couple of years 'stand alone' in my study connected to a Passive and some CX50s, and running with a PC.  One 'trick' was the ability to select and control a CD in the computer's CD drive using a Beolink Remote.
Here's a picture of it being tested - I used a VX sensor as the IR input:
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Oct 4 2018 11:04 PM
And further to the above I found my earlier thread on the subject, which may be useful: https://archivedforum2.beoworld.org/forums/t/5529.aspx?PageIndex=1
DMacri
United States
Posts 881
DMacri replied on Fri, Oct 5 2018 6:14 PM
So I must have something wrong. I have BM- link on my Mac Mini and I can hear music on the Beoport headphone jack. I am not able to hear music through my Masterlink converter connected to my BeoSystem 6500. Any settings needed to get this working?
Dom
Soren
Denmark
Posts 115
Soren replied on Fri, Oct 5 2018 7:32 PM
First,,,,I have no experience with Beoport, but the command N.MUSIC is identical to the command A.TAPE2 on your Beomaster so that may cause a conflict?? At least it does if you have a combination of Masterlink and Netlike like I do.
Søren
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Oct 5 2018 8:16 PM
As mentioned before, I don't think it will work with a BS6500 due to compatibility problems.  If you take the 6500 out of the system, and set up the Beoport as an Audiomaster (Option 2), does it work from other ML components? (Clearly it won't work over MCL as these need the 6500 to drive them).
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Oct 5 2018 8:19 PM
Soren:
Søren
Exactly.  It's probably the clash between N.MUSIC and TAPE.2 that causes the compatibility problem that I mentioned above.  How can the BS6500 know which input to look for when it is supplied with both?  It was the same with my BC9500.
DMacri
United States
Posts 881
DMacri replied on Fri, Oct 5 2018 10:36 PM
Is the Beoport compatible with a BeoSound 4000, then?
Dom
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Oct 6 2018 9:29 AM
DMacri:
I don't think so.  See here: https://archivedarchivedforum2.beoworld.org/forums/p/6400/47272.aspx
But you may wish to try it in Option 6 as mentioned in the thread.
DMacri
United States
Posts 881
DMacri replied on Sat, Oct 6 2018 10:47 PM
So sad, I guess I won’t be able to use it as I hoped. Thanks for the information.
Dom
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Oct 7 2018 5:19 AM
deleted
DMacri
United States
Posts 881
DMacri replied on Tue, Nov 13 2018 1:29 AM
Thanks for all of the help. I needed to follow the power up sequence in order to get normal operation, and also change out the datalink cable. One of the cables I had was not a bi-directional audio cable, it was only one way.
So the answer was to set the option settings for the BeoSystem 3 and BeoSystem 6500, remove power from them and the Beolink Converter, power the BS 3, then the BS 6500, and then finally, the Beolink converter. Now I have normal operation.
Dom
Page 1 of 1 (26 items) | RSS
