Beovisoion 8-40 with Ouverture masterlink
This post has 1 Reply | 0 Followers
jprombout1
Posts 8
jprombout1 Posted: Wed, Jun 20 2018 10:18 AM
Dear all,
I have reset my Beovision 8-40 and all of the sudden it does not pair with my ouverture anymore (masterlink)!?
Tried al the beo4 option settings on both devices, but somehow they don't recognize each other....
Normally I pressed A-aux in the list menu, and I had sound from the laptop via the ouverture coming out of the speakers system on the BV8, now nothing after te reset...
Any help is appreciated!!
Kind regards!
frog
Camberley UK
Posts 624
frog replied on Wed, Jun 20 2018 10:22 AM
Could be a few things; possibly the ML socket is dirty/loose - it happens with Overtures for some reason.  Check the socket and pull the ML plug out and put back in a few times then cycle the power on both devices.
secondly, check the options settings.
Page 1 of 1 (2 items) | RSS
