Beovision 10 11 14
This post has 16 Replies | 0 Followers
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael Posted: Sun, Jun 17 2018 8:12 PM
Hi
Did the BV10 have the connection panel at the top or is that only the 11 and 14 ?
Ferdinand
Malmö, Sweden
Posts 541
Ferdinand replied on Sun, Jun 17 2018 8:26 PM
My BV10-40 has all connections at the bottom
Ferdinand
Aussie Michael
Melbourne, AU
Posts 3,730
Thanks.
The hotel I stay has 2 BV in the room
It has a BV10-40 in the bedroom with no connection panel
The one in the lounge room has a connection panel but it has a fixed wall bracket so I can’t pull it forward to check lol.
trackbeo
Posts 644
trackbeo replied on Sun, Jun 17 2018 11:46 PM
I would bet that it does: The power cord goes into the same "hollow cable rail" as the other connections, so if you can find its entry point, you know where the plastic cover panel to that cable rail is.  Not sure how a hotel would go about making the cover non-removable, but screws come to mind.  The regular BV10 should have 3 magnets on the top edge of the cover and 2 or 3 rubber-on-plastic inserts (like speaker grilles often do) about a cm from the bottom of the cover and a few cm in from the ends.  Once you examine and access the TV that can be moved, you'll probably be able to pop the panel off the fixed-mount as well, because it takes very little horizontal movement to release the inserts, and probably the wall mount is deeper than that.  Hmm... should we look up the replacement part price so you can pay the hotel for cracked plastic bits?
Aussie Michael
Melbourne, AU
Posts 3,730
Lol.
I’m not referring to the connection panel below the screen.
I’m talking about the quick access one at the top
That is sometimes here
This is the bedroom one.
I was just wondering about the one in the other room that is fixed so I can’t see which model it is.
I very much like the picture quality.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Mon, Jun 18 2018 5:22 PM
Aussie Michael:
Lol.
BeoGreg
South of France
Posts 1,417
Only BV11 mk1 and mk2 had quick connections pannel.
Aussie Michael
Melbourne, AU
Posts 3,730
Thanks everyone. Worked it out.
The label was under the speaker cover.
It’s a BV11-40
The 11 has the better sound I think than the 10.
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Jun 18 2018 6:25 PM
Aussie Michael:
It’s a BV11-40
It sure has
Duels
England
Posts 2,553
Duels replied on Mon, Jun 18 2018 10:16 PM
Aussie Michael:
It’s a BV11-40
Yes it does.
Aussie Michael
Melbourne, AU
Posts 3,730
Interestingly the 10 has what looks like a centre speaker
But the 11 has a cluster of 3 in the left and right
The movies I watched on the 11 sounded way louder and clearer than my Avant.
But that could also do with the shape of the room and the 11 was in a little alcove.
tph
Denmark
Posts 161
tph replied on Tue, Jun 19 2018 1:26 PM
Aussie Michael:
In BeoVision 10 left and right channels share a single woofer – the suspected "centre speaker" – whereas the 11 has one woofer for each channel, together with their tweeters and midranges. This obviously results in better sound performance.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
Aussie Michael
Melbourne, AU
Posts 3,730
tph:
-- Tuomas // Bang & Olufsen Create
Thank you
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Tue, Jun 19 2018 5:44 PM
Aussie Michael:
And I believe you haven’t played with the settings.
I said it plenty times before and say it again : I found the BV11 sound fantastic (especially for movies).
Aussie Michael
Melbourne, AU
Posts 3,730
BeoGreg:
I’ve played with them
I think my issue is I reset the sound settings and it wasn’t the same. Even with tinkering.
That it I need to listen louder than 35
Rob - Danish AV
Melbourne
Posts 376
I do have some 11-40 with and without the quick assess panel.welcome to buy Stick out tongue
MK1 has no WISA but a quick access panel.
MK2 has WISA and the quick access panel.
Mk3+ has no quick access panel. Which is a shame, it was quite handy when i had an the early 11.
Aussie Michael
Melbourne, AU
Posts 3,730
Rob.B:
Page 1 of 1 (17 items) | RSS
