Hello all!
I was planning for a LOOONG time to buy a beolink gateway and the time has come! I have a few questions though and any help is more than welcome.
I have somfy shutter installed in my windows and some hue bulbs here and there. My goal is to control lighting, shutters, drapes, thermostat and doorbell via my beolink gateway. As far as thermostat is concerned I have installed a couple of months ago a NEST thermostat so "thermostat" is beolink compatible. Door bell I have ordered a birddoor which is recommended by B&O so no problem there!
So far so good but lighting and shutter is a bit tricky as I live in Greece and many of the B&O partners do not have any presence in the greek market. For example Caseta would be the perfect solution for me but Lutron does not have a distributor in Greece and the dimensions of the switches do not match the 80*80 dimensions of a European wall switch.
Fibaro is a company that has a similar system which is comprised by a hub and different receivers (for lighting, for motion detection etc etc). Fibaro's system is using ZWAVE technology like the HUE bulbs.
Does any one have used the Fibaro system in conjunction with the beolink gateway?
Do you know if ZWAVE is beolink gateway compatible?
https://www.fibaro.com/us/
Just add the z-wave modul to the Rpi and you have the support that you're looking for. I'm running with Domoticz on an Rpi2 + the Razberry board which works great and currently working on getting the implementation working with MasterLink using the old version of Masterlink Gateway.
Thank you for the replies. I will have a look at both the Vera and the raspberry solution. As my knowledge on programming is very limited could you please confirm that the raspberry solution is easy to program?
Thank you
Unfortunately not - you will need to work with custom strings on the gateway. Some programming on the raspberry. Not sure about z-wave plugins on the BLGW though - maybe that would be easier if there are some.
Hi, Just added a Vera System to the gateway it is on line but I have no clue what to add ? sorry not my field of expertise I use custom strings:
{ "u:SetLoadLevelTargetResponse": { "JobID": "18" } }
If I add the command in the browser it works
http://192.168.1.XX:3480/data_request?id=action&output_format=json&DeviceNum=17&serviceId=urn:upnp-org:serviceId:Dimming1&action=SetLoadLevelTarget&newLoadlevelTarget=30
If I paste this simply in the recource of the Vera plus I do not get a trigger?
Again sorry it should be simple but I am not a programmer
I have checked the vera plus and it looks that it covers the needs I have. Has any of you tried to connect the somfy Tahoma gateway to the beolink gateway?
