BeoLab 5 - High sound when switched on
This post has 9 Replies | 1 Follower
aengdal
Posts 6
aengdal Posted: Sun, Feb 17 2019 2:05 PM
Hi There,
My left speaker gives a high sound when it is switching on (activated). It sounds like a loose connection or overvoltage. All electronics (the chassis) was replaced 6 months ago, and I was wondering if it somehow was related to that.
Any ideas?
Cheers
Anders
Mr 10Percent
So West, Its Now East
Posts 591
Too vague a description but a quick guess of the lower end of serious is can you check if you’re upper tweets are preforming?
obtain some frequency test tracks (L&R) if you can find and see if all tones come through correctly.
I lost an upper tweeter once and  (don’t think I heard it pop but) but on replacement I quickly acsertained the second upper was not performing as well as or equally as the replacement. I would uly alwayes recommend replacing them as a pair
if the tones are correct, it’s internal electronics. If not, replace faulty drivers
aengdal
Posts 6
aengdal replied on Tue, Feb 19 2019 5:34 PM
I have requested a service guy. The chassis was replaced one year ago, and it's most likely the issue.
aengdal
Posts 6
aengdal replied on Sat, Mar 23 2019 1:29 PM
Once again..a new chassis (all electronic was replaced)
aengdal
Posts 6
GuyHUI
Paris, FRANCE
Posts 1,597
GuyHUI replied on Tue, Jun 2 2020 11:14 PM
Hello,
How much did it cost for the chassis replacement ? (MK1, MK2 or later version ?)
BV10 46" - BL5 to come... BS Ouverture, BC6000, BT1100
Old sold : BV Avant 28", BL8000 - BL4000 - BL2
RichardIII
Posts 61
That’s something I’d like to know as well
RichardIII
Posts 61
RichardIII
Posts 61
That’s something I’d like to know as well.
aengdal
Posts 6
aengdal replied on Wed, Jun 3 2020 8:18 PM
In the neighbourhood of €1,000.00.
It must be repaired by an authorised B&O service guy. When it has been repaired it will be configured as it was originally.
Page 1 of 1 (10 items) | RSS
