Hi all, I recently purchased a Beo4 remote for my BeoVision MX4000 TV. I am trying to test it to make sure that it is working properly before too much time passes in case I need to return it. According to the manual, pressing the "list" button is supposed to display different options on the screen such as "clock" or "stand" but nothing happens when I press the button. I'm I missing something? Thanks
Nevermind guys, I figured this out. For anyone having the same problem the solution was holding down the standby button and pressing list then selecting MX.
