I need to reset and delete previous handsets from a Beoline Mk2 base station. Can I do this at home or do I need to take it to the B&O engineer to be reset with the service tool?
I think my Beocom 2 is a Mk1 version, can it be upgraded to Mk2 spec via a software upgrade or does it need replacement circuits inside?
Thank you
