I recently picked up a Beocentre 2200 - without the MMC 5 Cartridge- if I can't pick a replacment up (as they do seem rare) - is it possible to replace the tonearm with something easier to find - or is there another cartridge I can use - I had heard that there is a Shure type that can be fitted ?
I have recently picked up a 2200 turntable, and I too am looking fot a compatible cartridge. I'm a complete novice to b&o and these furum things. π I also squired a 2000 amp/tuner and wondered it there are connectors that I can buy, that would allow me to use my existing speakers with the amp/tuner? As the connection on the back are different. Any info would be greatly appreciated.
I recently picked up a 2200 turntable. And it also needs a cartridge. Which carts are compatible with this turntable? I also squired a 2000 amp/tuner. And wondered if you can buy connectors that would enable me to use existing speakers. As the connection,s on the back are different. I'm new to b&o and these forum thingy,s. So any info would be greatly appreciated.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
According to the thread title this is a Beocenter 2200, which uses the MMC1-5 range of cartridges.Replacing the tonearm would spoil the looks and it would definitely not be an easy task.But why? - MMC cartridges are plentyful and worn ones can be rebuilt.
The speaker connections on your Beomaster 2000 is 2-pin DIN.That's actually the only industrial standard for home-stereo speaker connections in the world. Everything else is non-standard.Plugs can be found on Ebay etc. both as screw-mount and solder types. The latter is usually the best (if you can solder).
Scott: I have recently picked up a 2200 turntable, and I too am looking fot a compatible cartridge. I'm a complete novice to b&o and these furum things. π I also squired a 2000 amp/tuner and wondered it there are connectors that I can buy, that would allow me to use my existing speakers with the amp/tuner? As the connection on the back are different. Any info would be greatly appreciated.
You need these for the speakers:
https://www.ebay.co.uk/bhp/din-speaker-plug
