beogram 2404 tone arm wont set correctly
This post has 3 Replies | 0 Followers
MONMOUTH
Posts 2
Silver Member
MONMOUTH Posted: Tue, Jul 10 2018 7:11 PM
I am working on the above and have it all set but cant get the tone arm to set on the edge of the record. I have tried the 2 white eccentric's doesn't make a difference. Any one work on one of these and have a similar problem. any help appreciated
Thanks Jack
Søren Mexico
Mexico City
Posts 6,411
Does the arm lift off correctly by end of record, when returning to rest position is the arm parallel to the deck side ?
MONMOUTH
Posts 2
Silver Member
MONMOUTH replied on Wed, Jul 11 2018 8:22 PM
no the arm wont lift and also does not stop parallel to the edge no matter were it starts.
thanks
jack
Søren Mexico
Mexico City
Posts 6,411
Check, clean and lubricate the tonearm shaft and the bushing and mechanism for the lift up/down movement, did you clean and lubricate inside.
Page 1 of 1 (4 items) | RSS
