Trying to establish the year and model of my Beosound 9000 CD Player.
davminn
Posts 1
davminn Posted: Mon, Jul 30 2018 8:43 PM
Where can I find the serial number? It was put into service in 1998. Would it be a MKI or MKII?
Kiwi
Posts 21
Kiwi replied on Mon, Jul 30 2018 9:39 PM
Open the lid (not the glass door) to access the operation panel.
Remove the operation panel (by inserting your finger in the dedicated hole). It only holds by magnets.
Under the operation panel you'll find the serial number.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, Jul 30 2018 11:04 PM
The 'Type Number' is what you'll need to determine wether it's a Mk1 or Mk2.  It's a 4-Digit number beginning with 2***
Lee
Page 1 of 1 (3 items) | RSS
