Beogram 1500 type 5714
hpst
Posts 1
hpst Posted: Sat, Aug 4 2018 6:04 PM
Hello
Approxmately evry second time I press 33 it runs with near 100 rpm. 45 always runs normal. The mecanical speed-switch on th print works normaly.
Please help.
Hans Petter
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Aug 4 2018 9:55 PM
Common problem.
The belt is slipping. The motor then accellerates too easily and the electronics lock it to twice normal speed.
Cure: replace the belt.
I can supply a correct belt, if you don' thave one.
Page 1 of 1 (2 items) | RSS
