Good afternoon,
This is obviously not B&O related, but as many members see Loewe TVs as a suitable replacement for Beovisions, I found something that may be a deal breaker for some.
Apparently, the built-in surround decoder in Loewe TVs is very basic: it doesn't support Dolby True HD nor DTS-HD. Multichannel PCM is also not even supported. Multichannel PCM has been supported by B&O TVs since the Beosystem 3 platform. That means that if somebody wants to build a full surround system around a Loewe TV, he may be disappointed.
The discussion about this can be found here:
https://www.loewe-friends.de/viewtopic.php?t=8177
Translated link:
https://translate.google.com/translate?sl=de&tl=en&js=y&prev=_t&hl=fr&ie=UTF-8&u=https%3A%2F%2Fwww.loewe-friends.de%2Fviewtopic.php%3Ft%3D8177&edit-text=
You can use Google translate to translate from German if the link doesn't work.
Also, the current HDMI ARC cannot transmit the latest audio codecs nor multichannel PCM. We will have to wait for HDMI 2.1 for that.
The discussion thread is dated 2017.If the Loewe surround decoder has been upgraded since that, please correct me.
Regards,
Jean
BeoNut since '75
Chris Townsend:Based upon my personal experience, I find the Loewe processing of vocals far better. Too many times on my 10/11/7-55 I had to wind up the volume to hear the speech, only to be then deafened by the subsequent action. I’m sure based upon what the original poster said I’m missing out on some audio functions, but if does pretty damn well for a system costing £8,000 less. I can’t speak for the Eclipse of course.
I can also confirm that vocals on Loewe are far superior to other competition and I can safely keep a constant and low volume without loosing out on vocals. Regarding the multi channel surround, I am afraid that now I have a acronym fatigue. There was a time when I had to have 7.1 system running of Lexicon processors and mono amplifier but I am back to basics and have only 3 speaker system (BL 50 for right and left and Loewe TV as center in the main room and BL5 set up plus BV9 as center speaker in bedroom) for watching the movies and listen to music only in stereo mode and shut off the TV speaker. Just too much of non stop marketing creating a non stop need to upgrade. With sound, quality of speaker and cables matter a lot more than number of channels. BL5 and BL 50 made any other sound enhancement unnecessary.
Hope that helps,
people who have issue with vocals on a beosystem 3 based tv, didn't understood how to configure the level of their speakers.
that's amazing after several generation of beovision they still doesn't understand it.
level of center speaker on a 5.1 beosystem is not set directly, it is fixed by setting the level of front speaker lower or higher.
i owned several beovision 7 with beosystem 3 and never had any issue.
considering the fact a loewe tv isn't able to deal with multichannel pcm is just a shame actually.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
I had mentioned this solution at least one time.
It is a pitty Chris you suffered of this issue even on your last 7 55 mk2.
I still enjoy mine everyday. its picture is still great and I am glad to see it is able to deal with hd audio.
Very interesting, didn't know that at all.
It's evident that people hear what they want to hear.
Graham
