They are type 6802
Serial number - 17314312
those are MK2.
Ralph-Marcus
Thank you. Which part of the serial numbers tells this?
All of it, but mainly the 17****** part for quick reference. 163***** (from memory) was around the time the Mk1 crossed over to Mk2.
Lee
This information is provided on the product page of this website.
Does nobody bother to look any more?
The number you are looking for is 16992475
@9LEE I bet you miss my contributions, don't you!
Regards Graham
The place wouldn't be the same without you Graham!
