Managing two device with one BEO4
anyway60
Posts 7
anyway60 Posted: Tue, Mar 30 2021 8:06 PM
Hello,
I I have a little problem:
I have a Beocenter 2300 and a Beosystem 7000 placed nearby each otther.
Simply, when I press for example, the RADIO button with the remote  BEO4,  either the Beo2300 or the Beo7000 switch the radio on.
My  question is: it's possible to separate (maybe configuring properly  the BEO4) the activation of each one of systems as I need?
My BEO2300 is used to play only CD and Radio, Beosystem 7000 has attached my record player Pfroject so, I willl to separate with the BEO4 the  managing of the sources connected.
There's a solution for this matter?
Regards, Ivano
Millemissen
Flensborg, Denmark
Posts 14,680
The answer is here:
https://archivedforum2.beoworld.org/forums/t/46477.aspx
Millemissen
Flensborg, Denmark
Posts 14,680
Well - not really.....since you want to use one only
But you can set one of the systems to Option 4 and then use the ‘Link’ command (from the ‘List’) before pushing the actual function on the remote, when you want to activate that system.
Move ‘Link’ to the first place in the ‘List’ in order to have easy access to it.
Page 1 of 1 (3 items) | RSS
