hello is there someone here who knows the white point adjustment so I can go away from the really cold blue picture on my Beovision 10 and instead get a more warm picture like 6500 Kelvin?
Welcome to Beoworld!
From BV10 40 manual.
“Adjust picture
Adjust brightness, colour and contrast. For information on picture format, see p. 25. Adjustments made to the ‘TINT’ setting only apply to the current channel.
Press MENU to bring up ‘TV SETUP’ menu
Select ‘PICTURE’ menu
Enter and accept settings.”
I have no idea whether these adjustments will cover exactly what you are trying to achieve. Maybe a BV10 owner can help? You can access instruction and service manuals with a membership upgrade.
Graham
Hello thank you for your answer but I can’t change the cold picture in the regular settings i need to go into another setting menu but I don’t know what they should stand on the settings in the white point setting
Read through this thread... it may have the answer.
https://archivedforum2.beoworld.org/forums/p/4225/37691.aspx#37691
