HDR2 & Beovision 11
This post has 4 Replies | 0 Followers
Marek
Prague
Posts 33
Marek Posted: Sun, Aug 26 2018 6:59 PM
I'm fully satisfied Beovision 11 user. Unfortunately TV set doesn't have HDD recording installed.
I'm considering buying HDR2 - HDD recorder.
Is there any catch in connecting HDR2 to TV unit or just "plug&play" ?
thx
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Aug 26 2018 8:30 PM
I wonder if it’s worth the money...
Think there is only scart connection on that hdr2, so you need a scart to hdmi converter.
So the quality of the recording will not be good.
Better to look for streaming services.
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Aug 26 2018 8:37 PM
Hiort:
+1.  Also HDR2 relies upon a SCART connection to provide remote control via the TV.  As the BV11 has no SCART, you will not be able to control the HDR2 via the Beo4 remote, if at all.
koning
holland
Posts 4,220
koning replied on Sun, Aug 26 2018 9:39 PM
Humax 5400c is the better choice
Marek
Prague
Posts 33
Marek replied on Tue, Aug 28 2018 4:52 AM
THX - I did a bit of checking and realized there really is only SCART  connection but even worse there’s no chance to tune into DVB-T so it’s out of the question .....
m
Page 1 of 1 (5 items) | RSS
