Dear all,
Can I check beocom 2' s battery status in the phone' s menu (full charged or half charged)?
I found such menu item in beocom 6000 and beocom 5; It looks no such menu items in Beocom 2.
Any insight?
Thanks and with kind regards,
Daniel
I have not found such a menu item either. Supposedly, "The handset display informs you when the batteries require charging. If you have an active call, a beep signal sounds from the handset as well." (You would "View?" it as an "Alert" when it pops up on the display.) Since a fresh battery supposedly gives 150 hours standby time, and I like the looks of the phone best when it stands on the charging base, the issue hasn't arisen for me.
