Hello,
I’m still quite new to the BeoWorld, I’m just starting to dip my toes, therefore pardon me in case my questions might sound a bit naive.
I am currently looking for a pre-loved white BeoPlay V1-40 with the ambition of using it primarily as a wireless speaker for streaming music (Apple Music, Spotify, TuneIn) via Apple devices (both iOS and macOS), for an old audio system via Airport Express, then as a tv player of streamed content (Netflix and NAS).
Hence my questions.
1) I thought I had collected all the possible facts about the V1 in the past few weeks, while just today I have stumbled on the information that the WiFi antenna was an option! 😳
What if it is not included? Should I look for the OE Tyco antenna? If yes, any suggestion on where I can find it and estimated cost? If not, is there any alternate option you may suggest? Which 802.11 standard is complying to? Single or dual band?
2) I would like to add the 4K Apple TV, even though I am aware I will not benefit of the 4K and HDR features.
Would it still fit on the recessed rear channel? Would it work also as a WiFi receiver for the TV (then making the Tyco antenna unnecessary)? How can I control music streaming from old hi-fi+AE, speakers on and video turned off? Would casual gaming via A-TV have the same lag experienced with game consoles?
3) In case of future wireless audio expansion what would you suggest? Would it be possible to connect BeoPlay A6 or A9?
Well, while re-reading my post I have noticed that I have collected a fair amount of doubts, so I hope you Gentlemen can help to clarify at least some of them.
Thank you!
OlivierC
Hi Oliver,
if you can’t get the original receiver, a better way (maybe) would be to get a wireless access point with a network port and use to wire the V1.
The V1 definitely should be on your home network - the ATV4 can go wifi and most other modern devices too.
Where to hide this gear is another issue - I prefer having these in a cupboard or similar nearby.
The V1-40 is a good choice - especially when you consider the price.
Don’t expect to use the SmartTV functions - Youtube, Netradio and the DLNA client are very usefull, however.
In some cases you can program the tv to turn off the screen when listening to music only.
When not you can use the P.Mute function on the remote.
If you need to go budget, do consider buying a BeoPlay M3 and connect (NL) this to the V1 - might give you some more source options and B&O multiroom.
Also AirPlay2 to the ATV4/V1 and the M3 can give you yet another multiroom option.
Have fun with your ‘new’ V1.
jans, MM, thank you both for the prompt response.
From the information you have provided, it should be a “low risk” scenario.
Good to know!
Mine I will try to dig more from the sellers, then I will let you knw!
Cheers.
To 3.
The V1’s don’t have WiSA built-in - you’ll need the transmitter.
The M3/M5 are not speakers - they are ‘all in one music systems’.
The are supposed to connect to the V1 through NL (using the router-hardwire/wifi).
I know some people try to use the kine-in connections of the M3/5.
I would not advice to do this - it is too fiddly and won’t satisfy you in the end.
Get some preowned BL4000 (BL4 or alike) instead!
The buit-in netradio function in V1 is not TuneIn - personally I have had no problems finding the stations I need.
Thank you MM!
I will consider the speakers suggesiton for the future upgrade!
I have now added the pictures: do you (or other user) know why the Tyco antenna is not fitting in the channel?
Am I doing something wrong or is it supposed to be placed in a different position/area, outside the TV?
OliverC
Hi Oliver, am not sure if mine came with official B&O antenna or not, however from the picture mine is situated at the other end of the cabinet to yours, so not sure if that helps or not.
Have also used mine to wirelessly NetLink to an M5 and a BS2and it seems ok, although I can agree getting some BL4000, as they're amazing speakers and getting cheaper all the time.
For network radio either set-up N.Radio in the connections list, or I use the Receiver app on the AppleTv.
benjnz: For network radio either set-up N.Radio in the connections list, or I use the Receiver app on the AppleTv.
I would surely do the first.
If Oliver does not know yet - you can map the Netradio to Radio and start your radio stations directly from the (Beo4) remote.
You can even use the digits on the remote for a specific station - on the BeoRemote One you can use one (or more) of the quick buttons for easy accesss.
Getting to your favourite station via the ATV is much too fiddly.
As for the wifi dongle - never used it....my BV’s are hardwired 😉
MM, I think I will follow your suggestion, Netradio is selected via the Radio button.
This is leading me to another question: is it possible to remap the Beo4 A.MEM button with TuneIn instead of Deezer? If yes, would you plea provide a short how to?
madskp: I have now placed the ATV on the left side and the antenna on the right side of the channel but the cover is still not properly closing the compartment.
I am now assuming it is a cable management issue. I will try to get a shorter HDMI cable hoping it will help to better route the wires while reducing the volume.
I take the chance to share my opinion about some flaws I have found on the V1.
Please consider my notes with a grain of salt as I am a newbie, this is my first B&O product. Well, BeoPlay I should say.
I am far from being unhappy of the V1, this is mostly considered as the B&O “ugly duck” but I still see it as a wonderfully designed set.
The picture is very good when the Image is set to Movie (superbly deep blacks for an LCD display), the sound is great and the Beo4 is a superb remote control, I love it.
On the flip side I am still wondering if I’d buy another one in the future.
Some of the items I have listed above, such as the lack of product support due to the dismantle of the B&O tv team, might be roadblocks for my next buy as for the price the B&O products command, I am less keen to accept issues while my level of expectation is higher than what I would expect from the most common and lower positioned competitors.
Olivier
OlivierC: I am far from being unhappy of the V1, this is mostly considered as the B&O “ugly duck” but I still see it as a wonderfully designed set. The picture is very good when the Image is set to Movie (superbly deep blacks for an LCD display), the sound is great and the Beo4 is a superb remote control, I love it. On the flip side I am still wondering if I’d buy another one in the future. Some of the items I have listed above, such as the lack of product support due to the dismantle of the B&O tv team, might be roadblocks for my next buy as for the price the B&O products command, I am less keen to accept issues while my level of expectation is higher than what I would expect from the most common and lower positioned competitors. Cheers. Olivier
Some of the more conservative B&O afficianados' demurred against the styling of the V1 series when it first came out, but then, it went on to win a Red Spot design award, and the cries of angst appeared to diminish somewhat given it's design 'approval'.
For your purposes, as regards Wifi connectivity, yes, later model sets from mainstream manufacturers will offer more.
However, apart from it's lovely picture quality, the V1 also has a superb inbuilt surround sound processor, AND fully active speaker array which can do double duty as a centre channel in a surround sound A/V role.
Put that same active speaker system together with one of B&O's subs, and you have a superb HiFi music system into the bargain.
it really is a remarkable set, and outstanding value for money when new; mine is now 5 /12 years old, and my only concern will be what to replace it with when it eventually dies, as the likes of the Horizon for example, whilst having the same processor, does not have as good a speaker array, and whilst the screen is 4k, does not have Dolby Vision, HDR10, and yet is 3 times the price of the V1-40 when new.
In my view, B&O really need to make another V1-40 - as in a very high value for money TV capable of acting as the centrepiece in a B&O music/AV system. The Horizon is mostly there, but needs bigger screen options and Dolby Vision etc for the money being asked.
Cheers and enjoy your V1!
John
OlivierC: MM, I think I will follow your suggestion, Netradio is selected via the Radio button. This is leading me to another question: is it possible to remap the Beo4 A.MEM button with TuneIn instead of Deezer? If yes, would you plea provide a short how to? madskp: I have now placed the ATV on the left side and the antenna on the right side of the channel but the cover is still not properly closing the compartment. I am now assuming it is a cable management issue. I will try to get a shorter HDMI cable hoping it will help to better route the wires while reducing the volume. I take the chance to share my opinion about some flaws I have found on the V1. Please consider my notes with a grain of salt as I am a newbie, this is my first B&O product. Well, BeoPlay I should say. The USB port is not enabled for recording. Time to time the YouTube app is crashing. Ok, I also have the ATV but having YouTube integrated in the tv is still convenient. This tv has been discontinued in 2015 and the latest software update is dated 2017. If I am not wrong the current BV range has dropped the V1 OS and it has been replaced with Tizen. From what I have read in this forum, B&O has also dismantled the tv team in charge of tv/OS development, therefore I am not expecting further updates for addressing the issues. I am sure the B&O management had its own reasons to do so but from a customer perspective this is negatively affecting the user experience. I assume UE and product support are highly ranked by the B&O reference market. There is no DVB-T2 HEVC enabled tuner. By 2022 Italy will switch to this standardisation and all the non-conforming TVs, such as this one, will need an additional external box. I understand the V1 was developed before 2012, so this shortcoming is partially excused. The WiFi might have been better integrated instead of having an antenna as an extra piece to be hidden in the rear channel. Again, this tv was developed before 2012, however this is a premium product marketed at a much higher price (2.900,00 Euro when new) compared to the high range of Sony, Panasonic, LG etc. I am far from being unhappy of the V1, this is mostly considered as the B&O “ugly duck” but I still see it as a wonderfully designed set. The picture is very good when the Image is set to Movie (superbly deep blacks for an LCD display), the sound is great and the Beo4 is a superb remote control, I love it. On the flip side I am still wondering if I’d buy another one in the future. Some of the items I have listed above, such as the lack of product support due to the dismantle of the B&O tv team, might be roadblocks for my next buy as for the price the B&O products command, I am less keen to accept issues while my level of expectation is higher than what I would expect from the most common and lower positioned competitors. Cheers. Olivier
I love my V1-32, which I have in a secondary room.
If there had been a V1-55, I surely would have bought that for our living room.
To 2: Youtube isn’t crashing that much on my set. One thing I love is that you can choose the tv from within the Youtube app - as the receiver.
And that this even works when the tv is in stand-by.
To 3: Sure, there is no such DVB-t tuner there - wasn’t invented at that time.
If your set has an S-tuner built-in, this might help to get the channels you will miss....by 2022.
Note! In Germany the HEVC standart is already there - you are lucky, that you won’t have that problem untill 2022.
When you use the Beo4 (and have set the V1 for that), you can map the netradio to Radio.
Just remap the Deezer app to something else, or nothing in order to free that command.
You can even remove Deezer from the list of sources....if you want to.
Enjoy your V1 as is for now and for the next years.
When time comes, there will be other solutions - by 2022 we probably will be streaming tv programmes anyway.
The lack of 4K and HDR is no big deal with a 40” set - and SmartTV functions can easily be added....and PUC-controlled.
Hello Everyone,
thank you for the great feedback you are providing!
Hereunder some pics showing how I have arranged the wires on the back lid.
Maybe I am still doing something wrong as it is not perfectly closing.
About the YouTube app, my feeling is that it is crashing because of some SW issue, not because of poor wifi connection. BTW I don't have high hopes for some bug fixes in the future.
MM, I have been able to launch the video streaming from my iOS YouTube app but I'm not sure it works when the tv is in stand by. Is there any tv setting I should check?
I take the chance thank you for the hints on how to change the Beo4 button from Deezer to TuneIn, I will try as soon as I'll have time later this week.
Double post, sorry.
Please remove one, thanks!
OlivierC: MM, I have been able to launch the video streaming from my iOS YouTube app but I'm not sure it works when the tv is in stand by. Is there any tv setting I should check?
Have you made a quick start timer - or more?
The V1 must be visible on the network for this to work.
Hi MM, I have now found the correct setting in the menu where I can select to have a different power consumption stand by mode.
This selection can be adjusted for specific days/times and it allows a sort of wake up mode from external sources, such as YouTube app from the smartphone.
Great advice, thank you!
Just ask if not all of your questions are answered yet!
Last item, then thanks to the help of you BeoWorlders I have set everything, I swear!
Hereunder my current source list:
Source List
TV Tuner —> TV
Radio —> Radio
Homemedia —> H.Media
Webmedia —> DTV
Netradio —> N.Radio
YouTube —> YouTube
Deezer —>
Apple TV —> Apple TV
Hereunder would I’d like to have:
Plan A)
TuneIn —> A.Mem
The scope is to switch to the TuneIn app with the press of one button only.
Plan B)
If not possible ,switching to TuneIn via the List button of the Beo4 would be an acceptable alternative option.
Well - A.Mem is a one button action, isn’t it?
By the way - does your tv provider offer radio programmes on your cable/antenna?
Hmmmm - where does your TuneIn come from?
Yes, you are correct. I have both Radio and NetRadio options but I just wanted to learn how to configure Sources and Beo4.
Today is TuneIn embedded app, maybe tomorrow will be a different source. :-)
Is there a way to set TuneIn app with the A.Mem button?
Oh well, you have TuneIn as an app in the Webmedia section.
No, that is not possible.
But why, oh why do you need that - you already have two radio functions....ready for ‘one-button-action’.
What could you possibly find on TuneIn, that you can’t find on the Netradio of the tv?
I just wanted to learn how to configure A.Mem to something different than Deezer.
MM, thank you for all your valuable support
OlivierC: I just wanted to learn how to configure A.Mem to something different than Deezer. Olivier
You can - just free it from Deezer (set Deezer to none or something else) and you can assign A.Mem to what you like.....
.....just not to an integrated app - only the sources of the tv.
