I've recently discovered half-speed mastered LPs that play back at 45 speed. I'm just curious if anyone is aware if there is a B&O remote command that can switch between 33 and 45. I'm doubtful, but thought if any one knows they would be on this forum.
i don't know but maybe the key 'Turn' (Beolink 1000) might do this job.
Ralph-Marcus
On slightly newer BL1000, 'TURN' is 'SHIFT' then 'SOUND'
But I am pretty sure that LP speed selection has to be done manually - the BC9500 user manual says so.
I tried the "turn" command. However, it brought up the menu for sound modes on the Beosystem 4. Thanks for the suggestion, though.
It was quite a useful exercise for me too - I have now realised that on my BC9500 the TURN command switches between mono and stereo when listening to FM
