Hi
I will bring my BeoLab1 speakers to the USA. I assume that these euro speaker need to be adjusted to accept 110v?
How easy is this done?
Thanks!
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Beolab 9 | Beolab 8000 | Beolab 6000 | Beolab 2 | Beolab 3 | Beosound 9000 | Beoplay A9 | Beomaster 8000 | Beovox M75, / S75, / S45.2
Much obliged to both of you for fast, on the point responses!
I always thought that the BL1 had the same basic electronic chassis as the BL9, which would make them worldwide 100-240v capable?
Check on the rear if that's true, if so a simple power cord change is all that might be needed.
You can call ahead and ask a major USA service centre for a price on the following:
2x backup suitcases for Beolab 1 Type 6843 (USA 120V Part 3395146). They may even have some spares from a process completed previously.
Or ask a service centre in Sweden if they have some spares as well from the reverse process.
Many years ago the Australian service in Camberwell used to provide a similar service for those from the USA which was about AU$400.
Good luck Beoaus.
