Beolink Converter NL/ML setup
Beosince98
Posts 274
Beosince98 Posted: Tue, Oct 9 2018 6:32 PM
I have recently acquired a used blink converter and am stuck with the setup. The NL/ML converter is connected only to a Beosound 9000 MK3. Is there a detailed manual or could somebody help?
Thank you!
Soren
Denmark
Posts 115
Soren replied on Tue, Oct 9 2018 8:35 PM
Hi
You can find almost everything there is to know in the Beolink handbook😊
http://www.echo14.com/wp-content/uploads/Handbook.pdf
May i ask...If you only have an audio master what do you want to achieve with the converter
Søren
Beosince98
Posts 274
Soren:
Hi
Søren
It does not detail how to set up the converter, but I kind of figured it out myself. I wanted to connect the Beosound 9000 so I have to press a singe button to listen to music on my TV. Also, I wanted to add another „room“ to my multiroom setup. The Tv is located in a different room and I can not control the Beosound 9000 without the converter.
Page 1 of 1 (3 items) | RSS
