Hi everyone
First of all I apologise for buying a generic remote control for my free b&o TV. Just finances that's all.
For some reason when I press the menu button in order to the the tv all i keep getting is a screen that says
Tv set (in a box top left hand)
With two what looks like pictures of leads going down to
1 v. TAPE-1 / NEW
2 V.TAPE-2 / NEW
Any help with this will be much appreciated.
The generic remote is a classic irc81181
Thank you in advance
Jamie
BeoNut since '75
Hi Jamie, Did you solve the problem? i own a mx3500 with a beo4 remote and experience the same problem. Thanks,Daan
Hi Lawrence - it's been discussed here: https://archivedforum2.beoworld.org/forums/p/14476/260657.aspx#260657
and hopefully resolved!
