4600 record player not staying on
This post has 7 Replies | 0 Followers
Guttee
Posts 6
Guttee Posted: Fri, Oct 5 2018 4:03 PM
hello everyone new member here. Just got a 4600 off my dad which is in great shape. Only problem I have is that the turntable won’t sstay on after pressing the 33 or 45 button. Can anyone help thanks
Andrew
Frinton, UK
Posts 917
Andrew replied on Wed, Oct 10 2018 10:59 AM
Hi - have you checked the belt and that the motor is running - you can do this by lifting up the platter?
Guttee
Posts 6
Guttee replied on Thu, Oct 11 2018 2:26 AM
Yes the motor turns for a second or two then stops. The belt does slip a bit but if I press the turn button it will run longer. Would a slack belt cause it not to kick in when running auto
Guttee
Posts 6
Guttee
Posts 6
Guttee
Posts 6
Andrew
Frinton, UK
Posts 917
Andrew replied on Tue, Oct 16 2018 1:25 PM
Hi - sounds like a problem either with the motor or something else - sorry, I can't offer more help but there maybe others on here that have more info,
Andrew
Frinton, UK
Posts 917
Andrew replied on Tue, Oct 16 2018 1:26 PM
Page 1 of 1 (8 items) | RSS
