Is there an original version of beolab 2500 without the relay?
Cora2
Posts 5
Cora2 Posted: Sun, Jul 29 2018 8:53 PM
I have purchased a set of Beolab 2500 type 6201 serial 10690026 where the LED stays green indicating power on. They work fine except for not switching the power of, it's always on.
I opened the case to find that there is no relay for the switching in the designed space for the relay. The bypass wiring however seems professional, certainly not a quick fix.
My question is: Is there an original version without the power switching like mine or is it likely to be added/changed later?
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Jul 31 2018 6:45 AM
Cora2:
Most likely changed later. Makes no sense to create a version that does not go into std.by. I have never seen a pair that does not switch off.
/Jacob
Cora2
Posts 5
Cora2 replied on Sun, Oct 21 2018 9:21 PM
Thank you,
I will add the relay components.
Coen
Page 1 of 1 (3 items) | RSS
