Dear all,
I check the beolink handbook, and I notice following:
- Option 5: Two IR receivers in the same link room - 1 audio product and 1 video product
- Option 6: One IR receiver in the link room
My question is what will happen if I use option 6 for 2 products (1 audio and 1 video) in the link room? I will push LINK + Radio / CD / A.MEM for audio and push LINK + TV / DTV / V.MEM for video product in anyway - the button will no be conflict, right?
Anybody has such knowledge?
Hi
If you want to use the command “LINK” for your Lokal products they must be set in option 4.... if you put a video product in option 6 it will forward all audio commands to the main room, and pressing ie DVD it will start the Lokal DVD player.... if you press LINK DVD it will call for the DVD in the main room.
I hope it makes a little sense.
Søren
And if you put in option 5 it will not forward the audio commands to the mai room, unless your press “LINK” before the audio commands
