How to change the line-in of the B&O Transmitter 1?
crossisan
Posts 2
crossisan Posted: Sat, Oct 27 2018 4:03 PM
Hi all,
I am new on that forum and looking for help. I hope this is the right way to do.
Can someone help me in getting the line-in setups of the transmitter 1 changed. The issue is that I do not get the transmitter download the WLPSETUP.TXT file to the USB stick and the Manual is not very clear for this point. It just states:
- insert an empty stick into USB-A connector
- the Transmitter will then create a file on the USB memory........
but it does not Sad
It is not said if the transmitter needs to be connected to the mains or not, how long the stick needs to stay in the slot etc.
I tried several times, but no success: the USB stick remains empty (FAT32, no files before use)
Thanks a lot in advance for your help
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce replied on Sat, Oct 27 2018 6:03 PM
Maybe the usb stick must be plugged in before turning on transmitter 1 to write the file ?
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
crossisan
Posts 2
crossisan replied on Sun, Oct 28 2018 4:56 PM
Hi BeoIce,
thanks for the quick reply.
I did what you suggested, and in fact, contrary to what happened before, the transmitter wrote SOMERTHING to the USB stick: a lot of unidentifiable folders ("journals.xxxxx", but all empty) and files, but nothing which looks like the expected WLPSETUP.TXT.
- I disconnected the transmitter from the mains
- I put the stick into the slot
- reconnection to the mains
- red control light of transmitter switched on, stick was blinking. After a short moment red light switched off, stick stopped blinking
-disconnection from mains
- removal of stick
- read out of stick in PC --> nothing useable found
Page 1 of 1 (3 items) | RSS
