IR eye stops working on Beosystem 2
This post has 9 Replies | 1 Follower
Dutchdennis
Posts 6
Dutchdennis Posted: Fri, Oct 19 2018 10:02 PM
I recently bought a second hand Beosystem 2 with a Beovision 4-65 and all the cabling. The only part that wasn’t included was the IR eye, so I bought a second hand one.
i can switch the system on with the remote and operate the menu, but the moment I switch to DVD or TV the remote stops working. Unplugging the IR eye from the Beosystem 2 doesn’t reset it, only manually switching the Beosystem 2 off and on gets the IR eye to work again  Until I switch to TV or DVD
I’ve never posted on a forum before, but I’ve been trawling the Internet for weeks now and I can’t seem to find a solution.
The IR eye is a 5 screw model and it’s conmected to the Beosystem 2 with three wires in a soldered headphone style connection.
w5bno123
London
Posts 578
w5bno123 replied on Fri, Oct 19 2018 10:59 PM
Hello and welcome. Do you have the eye wired like this?
Dutchdennis
Posts 6
Thank you for the diagram, I did follow those instructions she. I connected the eye up:
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sat, Oct 20 2018 1:39 PM
Check setup settings at the connections. Whem there is DTV-DVI or DVD-DVI is choosen, then the screen has probably a DVI module mounted.
From the moment you choose DVD , the videopath through the BS2 will be bypassed and instructions from the remote aren't visable anymore.
Dutchdennis
Posts 6
There are no connections to the tv other than the rs232 and the vga cable. I’ve hooked  my DVD player to the scart port on the Beosystem. If I select dvd or tv the remote completely stops working.
Could the Beosystem 2 be broken?
w5bno123
London
Posts 578
w5bno123 replied on Sun, Oct 21 2018 10:15 PM
Dutchdennis:
If it is broken it’s beyond economical repair, no spare parts available. We have a clients BS3 on eBay right now which is a much better unit
Dutchdennis
Posts 6
I borrowed another Beosystem, but exactly the same Happens: the system responds to the remote control in the menu environment, but whenever I switch to TV or DVD or anything else the Beosystem stops responding to the remote.
Witg the IT eye working in menu setting, I’d rule out a wiring issue, so it must be a faulty IR eye
Beobuddy
Posts 3,972
Beobuddy replied on Tue, Oct 30 2018 8:56 AM
Sounds more of a issue of interference from the plasma on the ir receiver.
Place the ir receiver directly on the wall beneath the plasma.
Dutchdennis
Posts 6
You’ve won the cake sir!
When I bought the TV, not all the cables were included, so I used a generic monitor cable and a generic straight RS232 cable.
I’ve switched the TV off and lo and behold: the IR eye is working again!
I’ll buy some clip on ferrite for both cables, see if that fixes it
Dutchdennis
Posts 6
Page 1 of 1 (10 items) | RSS
