Hi all, quite fancy dusting off the vinyls and listening to them through my lab9s, they are currently connected to and driven by my moment. Can I intergrate a Beogram in to this set up? If so, is it any Beogram or just certain models. Never really looked at B and O turntables before, any major pitfalls I should be aware of?
Thanak in advance
james
Beovision 10, Beoplay V1, Beolab 17, Beolab 9, Beolab 4, Beosound 2, Beosound Moment x 2, Beoplay M3, Beogram 1700
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
One thing that you have to look for, when you buy a used BeoGram turntable is the needle/the pickup.
These are usually quite expensive, so be sure that you can see the turntable and hear it playing..........before you purchase one.
Hi James,
Yes, this can be done! Please see this link for details of which Beogram models need a pre-amplifier to be added when used with the Moment:-
http://www.soundsheavenly.com/faq/question/beogram-turntables-need-external-pre-amplifier-kit/
When I buy a new Beogram for use at home, I get a new SMMC4 cartridge from Sound Smith in the USA, these work perfectly and last for years, they sound far better than the original B&O cartridges (which are usually well over 25 years old by now).
Alternatively, any other brand of turntable can be used with the Moment - please feel free to drop me a line via my sponsor link below once you have chosen your turntable, then I can help you to get everything connected.
Kind regards, Steve.
Steve.
leosgonewild:Buy a new record player instead. Then you can get a new pick-up instead of some “don’t know how long it will work”-MMCx Personally I will buy a Pro-ject with a blue or black pickup from Ortofon
DMacri: I’ve owned other turntables in the past and always noted they pick up any footsteps in the room. You could see the effect by watching the woofers pulsing violently when the volume is up and you walk across the room. I see none of that with Beograms. Are there current products from other vendors that can match this? I never seem to see this mentioned in magazine reviews.
Turntable and cd player wall mounted,no problems with footsteps/vibrations
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
