Since I have Beosystem 5000 regularly on Sundays at 6 am and at midnight, I have a radio on P4 along with a tape recorder. I understand that once, someone has programmed it to record. Truth ?? Now help me... how to turn it off !!! Because on Sundays I do not sleep long. I can not sleep early.
BeO is like a good wine - the older the better...
Finally, I found a separate manual for MCP5000. Under the flap in the PROGRAM block, press STEP and each time it is pressed, it shows us the programmed switching on. When after pressing STEP and displaying the program, press CLEAR the program will be deleted.
Managed to. There were 3 progams for me.
