i have just got a Beogram 1000 that needs repairing. When it operates there is a rubbing sound as the platter rotates. I removed the platter. Should there be some sort of bearing between the platter and the chassis or does it just require lubricating with grease.
thanks
chris
Transport screws ? get the manual available for silver and gold members, and here a link that may be of help
Something wrong with the serbian capitol?
There are no transport screws in Beogram 1000.Did you lift the platter right off?In that case there will be one or more screws missing.
Which version of Beogram 1000 do you have? Photos?
Thanks for the responses.
the model is a gr1000v type 5203.
i have removed the platter completely from the unit.
i am having problems uploading photos from my iphone for some reason.
Chris
