Update a factory resetted BeoSound 5
This post has 13 Replies | 2 Followers
northswede
Stockholm - Sweden
Posts 43
northswede Posted: Wed, Jul 17 2019 5:27 PM
I have factory resetted my BeoSound 5, but now I can't update the system since the system can't connect to the B&O update server.
Is there a way to get the latest SW version some other way?
Best regards
Northswede
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Jul 17 2019 6:39 PM
northswede:
Best regards
Northswede
For about a month ago, I did the same, at that point the server worked fine. Are you sure your unit has access to the internet ?
/Weebyx
delroy
Posts 43
delroy replied on Wed, Jul 17 2019 9:15 PM
I’m pretty sure the servers are down. I can’t connect to them either...
northswede
Stockholm - Sweden
Posts 43
northswede replied on Thu, Jul 18 2019 11:28 AM
Seems that I just missed the last update from the servers.
Well, the question still remains; Is there a way to update a BS5/BM5 to the latest SW off-line?
Esax
Posts 323
Esax replied on Fri, Jul 19 2019 12:18 PM
What’s the latest software?
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Jul 22 2019 12:44 AM
my BeoMaster 5 gives the following information:
BM5 OS Image: 7.02 (it's the version on the Harddisk itself)
BM5 OS Update: 7.03 (Update Version for the BM5 OS Image)
BM5 Application: 7.04.01.1945
But it's not only the Update Server which is not available but also the connection for N.Radio updates gives a 'Server not available' message. But this message comes also when the BeoPlayer application on my Computer tries to get an update for N.Radio.
Ralph-Marcus
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Aug 19 2019 10:06 AM
northswede:
Best regards
Northswede
Did the servers come online again ?
/Weebyx
northswede
Stockholm - Sweden
Posts 43
Weebyx:
/Weebyx
Sadly not to my knowledge, I opened an support case but was asked to contact my dealer after some problem solving attempt from B&O support.
My solution was to sell my device in it's factory reseted state.
//Northswede
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Aug 21 2019 7:09 AM
northswede:
Weebyx:
/Weebyx
//Northswede
So what about the radio stations ? They cannot be downloaded either after factory reset ?
This is sad, as it effectively renders the Beosound 5's that need new MB or HDD useless after a complete reset with the USB service tool ?
/Weebyx
TWG
Posts 1,672
TWG replied on Wed, Aug 21 2019 8:33 AM
After factory reset you'll still have a HDD audio player with Beo 4 / 5 / 6, Masterlink, MLGW and BLGW support.
Maybe somebody does have a clean Beomaster 5 with all the latest updates and can upload a discimage or something like that which can be used for future Beomaster 5 repairs.
Or if somebody knows where the updates are saved on the Beomaster 5 harddrive, only the updates can be uploaded to be save for future repairs.
RaMaBo
near Munich
Posts 626
RaMaBo replied on Sat, Aug 24 2019 11:56 AM
there's still an update available on the B&O server which is 200 MB in size.
If you check your Beomaster System on Drive D: there's a directory called 'D:\SWUpdate'. It should contain a file called 'UpdateInfo.txt' with a link to the newest version and where to place the downloaded file:
'07.04.01.1945;http://swupdate.bang-olufsen.com.gccdn.net/ftp/BeoMaster5/Mk1/Prod/SWService/BeoMaster5_704011945.exe;D:\SWUpdate\Packages\BeoMaster5_704011945.exe'
There are also some directorys 'AboutInfo', 'Packages' and 'Updateinfo'.
The update may be only usable for a system based on the image 7.02 which was on the disk of my Beomaster..
As i don't own a BeoSystem 5 i don't have a link for the latest BeoSystem version..
Controlling some Logfiles ('E:\BM-Share\Log') of the System it shows that the B&O Update Server was not avilable in July but is online right now since 30.07.19
I hope this helps a bit to save this nice piece of B&O computer device.
I boght my BM5 as defect, non starting, and replacedthe mainboard with a EPIA 1,5GHz version which contained an original B&O BIOS chip (?!?!) but was replace with the original chip from the nonfunctioning mainboard Smile
Activated Twonkyserver on the BM5 and installed TightVNC for remote access.
Ralph-Marcus
beolion
Posts 485
beolion replied on Sat, Aug 24 2019 8:22 PM
Hi
The filename is the same as on my BS5.
And I just made a copy, just in case.
beolion
Posts 485
Double post.............
Frederic
Belgium
Posts 121
Frederic replied on Sun, Aug 25 2019 5:16 PM
I saw that the radio stations were updated as recently as august 23rd so I assume Radio is and hopefully will be working for a long time to go
Page 1 of 1 (14 items) | RSS
